TR2/3/3A TR3A Rear Bulkhead
houleyh
Is there a carboard or a wood veneer that goes between the fuel tank and the rear bulkhead? If so, anyone has a source, details or dimensions?
Thanks
VB is the only source yhat I found. But if you get a trunk carpet kit from Moss it is in the set. Or I could make you a template and send it to you.
Sorry Dan, I am not talking about a panel in the trunk. I am looking for the panel that should support the vinyl panel in the back of the car (the back seat) ...Sorry
Nothing there on a 3 or 4 or....
There were several different styles of panel before TS60K, one of which did have a partial metal panel at the top. But all of them were just pressboard at the bottom, AFAIK. And as Andy says, that was all between the vinyl (or Vynide) interior and the tank itself.
Both my TR3's had the metal top part on this.
Here's a view of mine as I was recovering it. As I recall, that 1x2 is something I added to stiffen the old masonite.
Yvan - The rear of my 1958 TR3A has the 2-piece assembly like George shows. Mine has the steel top like his, but where he has masonite, I have a piece of 5/16" thick plywood. The steel has a bend in it where it attaches with screws or rivets along the top on the plywood and the top of the steel has some jute-like padding as you might use to pad the arms of an arm-chair before you put on the final covering. My original back piece of vinyl was sewn in strips to give the horizontal result. The new one from 1990 is leather and is made the same way with sewn strips.
On the later TR3A we restored (TS 81551 L) the rear was a one-piece panel like masonite which had been softened (perhaps in water) and curved along the top for the shelf where the hood stick assembly rests when it's folded down. The red coloured vinyl on that later rear panel was one piece (not sewn) and was moulded all in one piece.
