M_Pied_Lourd
Hi Guys,
Well, the test engine start didn't go so well today. Had it running for about 10 seconds on ether before shutting it down as it was revving to about 3000 rpms.
We are getting spark at the plugs. We installed an electric fuel pump and have flow to the float bowls. We took the cap off the float bowls and manual filled the bowls as well. Took the jets out, cleaned reinstalled/centered etc.
Checked the plugs after alot of cranking and I am thinking that they should be quite wet but they are dry. So definately wondering about this...
BTW, we did swap out an extra set of carbs and swapped out for a different dizzy with pertronix installed but no difference.
Pretty much out of ideas at the moment..
So, any suggestions from the experts on where to start with my non start issues?
Cheers,
M. Pied Lourd
Cheers,
M. Pied Lourd
