TR2/3/3A TR3A No Start?.....Petroronix???
karls59tr
Bronze
Took the Tr out for a fast run this afternoon. After it sat for awhile and I tried to start it was no go. It cranks but won't fire. There is no spark to the plugs and no spark to the distributor center wire. I wonder if the Petronix has failed? Had it for years with no problem. What test should I do next? Any advice most appreciated.
Karl
Geo Hahn
Many Pertronix users carry a set of points for just such a moment. If you have a set, that is what I would try.
...Had it for years with no problem...
Alas, that's the thing about electronic bits... they can work well right up until the moment they don't.
TR3driver
Great Pumpkin - R.I.P
Before that, I'd make sure you are getting power to the coil/Pertronix. Just a quick test with a voltmeter or test light.
I feel the Pertronix is most likely too; but I feel it's still worth checking the easy things first.
And, just because I've gotten burned a couple of times (on non-TRs), check that the distributor is actually turning. Just leave the cap off and hit the starter button under the hood to see if the rotor turns.
dougie
I had the same problem with my '65 3000 MKiII. I had the Pertronix on it for 10+ years. Replaced the coil, dizzy cap, Pertronix unit, and nothing. Turns out a little bit of rust had developed under the rotor which cause a lack of contact. Replaced that and it fired right up. I now have a boot full of spares....
K
karls59tr
Bronze
Good call Randall. The wire to the dizzy had pulled out of it's female connector at the fuse box. Best to check the simple things first.
However like CJD suggested I'm going to keep a point set in the car in case the Petronix does go south.
TR3driver
It's awfully fiddly to install points on the side of the road, especially if you drop the nut into the dizzy. I carried an entire point plate for awhile, with points installed and gapped. Then after seeing a local club member stuck on the way home from Portland by a bad rotor; I started carrying an entire distributor, with points, wires and all, in the middle of the spare tire. There is just room for a set of hoses, a fan belt, some fuel line and a Facet electric fuel pump with fittings. I've never needed the fuel pump, but it did come in handy when a member of our caravan ran out of fuel. Everything else I've needed at least once iover the years (and not always had).
doc50
Just had Advanced Distributor make up a new one for me. I went with points because the owner, Jeff told me that Pertronix modules don't work well in these distributors. Something about random misses because the spacing is too close and there is some magnetic/electrical interference.
That explanation is from a rank amateur (me), of course.
Geo Hahn
... I started carrying an entire distributor, with points, wires and all, in the middle of the spare tire...
Me too. For these cars you can just about hold an entire ignition system in one hand.
If you set it up beforehand (set gap & timing) it is just a drop in to get you going again.
Tinkerman TR2/3/3A 60 TR3A wont start??????????????? Triumph 7
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
H TR2/3/3A TR3A Won't Start Triumph 15
S TR2/3/3A TR3A Will Not Start Triumph 55
M_Pied_Lourd TR2/3/3A TR3A No Start Triumph 37
Bremer TR2/3/3A TR3A no start Triumph 17
Skip_Shervington TR2/3/3A TR3A Start Problem [Solenoid?] Triumph 5
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
