angelfj1
The horn in my 3A stopped working recently. I checked all of the obvious things. The horns do sound when connected by jumper to the battery. The fuse is OK. The wiring to the horns is OK as there is a constant 12V at the horns. I isolated the NB wire coming from the steering column harness and connected my digital multi-meter to it (on the ohm scale) and to earth and then pushed the horn button. The meter reads inf. or open circuit. I have heard of situations where the horn circuit would short out and the horn would sound during a turn or with heavy torque on the wheel. However, I was not aware that they could fail as an open circuit. This car has clocked a few thousand miles since a complete restoration in 2012 and has been garaged ever since. The control head was new from TRF when installed. This car has an adjustable steering wheel. In order to further diagnose this problem does the control head have to be removed?
Thanks, Frank
Thanks, Frank
