Could anyone identify these (disconnected) wires?
First comes from what looks like a condensor (?) at the side of the voltage regulator. One black wire (in my fingers) is disconnected - second black wire runs from the "condensor" to behind the terminal block under the regulator.
Regulator block
Second pic has two mystery wires. Dirty red with female spade connector runs up over heater box. (Heater motor runs fine). Blue wire with white tracer (bare end) runs through firewall; can't find its "exit" in engine bay. Also, note "drain hose" running from behind heater (?) to passenger footwell.
Underdash
Only thing that doesn't work on the dash is panel lights.
Thanks.
Tom
Regulator block
Underdash
Thanks.
Tom
