mapleaf said:
Thanks guys, I had a 'cherry bomb' muffler on it years ago but found it to loud. I'm hoping to find a less expensive alternative to the stainless system and noticed that Moss sells one (pt#862-000) that is supposed have the "raucous" sound of an original. If there is anyone on the list who has tried this muffler would you let me know your opinion.
The Moss unit is a good reproduction of the original ... which means it IS a straight-through "glasspack" type muffler. The major difference between it and a "Cherry Bomb" is the construction of the outer shell; the Moss unit is made from several panels rolled together at the seams (as original) while the Cherry Bomb has a one piece welded outer shell.
I ran 862-000 plus 862-010 for approx 17 years and felt the sound was about right, until all the glass fiber blew out. Then it was really too loud for my tastes (but being cheap I continued to drive it until it broke).
Can't prove it, but IMO the main reason mild steel exhaust systems used to rot out so quickly was lead in the fuel. They seem to last much longer with unleaded.
When the Moss unit finally did fail, it was because the rear panel broke rather than rusting out. Likely I didn't have it properly supported, as I never could get that center mount to last very long.
BTW, just for clarity, "Cherry Bomb" is a brand name and they offer several different types of mufflers under that name. I'm talking specifically about the "performance glasspack" Cherry Bomb as that's what I had.
https://www.cherrybomb.com/sitemap.html
Anyway, IMO if you were unhappy with a single Cherry Bomb (in good condition, not with the glass blown out), then you'll be similarly unhappy with just the one unit from Moss. Adding a second unit from either source will help, though.
