I'm currently performing the initial rear brake adjustment on the rolling chassis, and would like some feedback. Per the service manual, I engaged the wedge into the adjuster housing until the drum could no longer turn, and then backed out 1 notch. At this setting, the drums appear to spin freely; however, when I engage the hand brake and release, there is some drag that doesn't go away when spinning the drum by hand. During assembly, I did check to ensure the cylinder moves inside the backing plate, but I wouldn't say it easily slides back and forth. My best guess is that when I engage the handbrake, the cylinder doesn't completely move back to the location where there is no drag. Is this normal behavior for a rebuild with new brake pads? I'm thinking this may be a non-issue after going through a normal break-in period.
Hi Guest!
