Gentlemen,
As part of my back and forth with Mark Macy on his new fan (which I ordered) he provided his view of the bellows thermostat as follows:
"We install the bellows thermostats in every car and engine webuild, probably about 30 a year. We have had only one failure in the pasttwo years, so overall they are pretty reliable. I will mention that thelarge OD flange is slightly oversized and may not seat perfectly in the recessof some water outlet housings, and we have to check closely and sand down thisflange to get them to seat properly. It is possible that some of thefailures could be caused by this flange getting "tweaked" if itdoesn't seat correctly, and possibly put the bellows assembly in a bind. Whether you use the sleeved thermostat or block the bypass, you have to slow orstop the return of hot water to the block if you want these cars to runcool. If you go with the blocked bypass, then by all means be sure todrill a 1/4" hole in the plug so that some water can flow and prevent airpockets."
Regards,
Walter
Regards,
Walter
