I fired up the TR and took it for it's first short test hop down the street (slightly illegal) . Had a good firm petal before I started off and the handbrake worked perfectly. After the first application of brakes, the front disks are firmly still on. The car will move, but will not coast at all. The calipers are brand new Moss units as are the pads; I drilled out the restrictor valve after I had trouble bleeding the brakes and finding an earlier post about problems with that valve; - why would the pressure at the disks remain high after I'm off the brake petal? Help
Stu
Stu
Hi Guest!
