jdubois
Is that sucker supposed to be on when the indicator switch is not engaged? Somebody did a very strange rewire job on it, adding some wires and sending the ground on the light to a weird place. The dash light has never worked since I've known the car.
So I pulled all the homemade wiring and put the wiring back to match the factory schematic (and replaced the flasher unit for good measure). Now it works fine, except that the dash light is on all the time (except when the indicator switch is engaged, then the light flashes correctly.)
The circuit is so simple, it was easy to verify that I've got the external wiring to the flasher unit correct now (switched/fused 12VDC to the X terminal, indicator switch on the L terminal, and dash light on the P terminal). So either this is the way it's supposed to be, or my new flasher unit doesn't work right. (I put back the old flasher unit, and it doesn't light up the dash bulb like this one, but only flashes the bulb once on switch activation, though does flash the side and tail lamps correctly)
