Wanted TR3A control head parts (trafficator)
Frank Canale
I am in need of the base to the control head. This is the part that has the studs to connect the wiring harness to.
The one I need includes the triangle piece #9 center is molded to piece #6 as one unit. Thank you in advance Frank
Anybody solve this problem: my right turn signal and horn button work. But the left turn signal does not. Rather than disassembling the trafficator, is there a way to lubricate the mechanism inside the trafficator without total disassembly? The wiring seems intact.
I have my trafficator disassembled in order to find what was broken or need of maintenance. My trafficator was removed without making sure the wiring was free and internal connections were broken. I do not see how you could lubricate the inside or know for sure what is not working without taking it apart. The Roadster Factory has complete units on sale. Parts are scarce and this unit has bakelite parts that are brittle and that is where failure usually happens. Good luck Frank
