TR2/3/3A TR3A coil
6TTR3A
<span style="font-size: 11pt"><span style="color: #003300">[/color]I'm not having any problems with my coil (Lucas HA 12, 45102E,Mfr d. June, 1960), but before I install an electronic ignition, I want to make sure its OK.
I can't find the resistance specs anywhere. Neither my Bentley's or my Haynes makes any mention of coil specs.
I've got 3.2 ohms across the primary, which Petronix says is OK, but I've got 6.7 ohms across the secondary, which no one I've talked to can confirm or deny is OK.
Lucas.UK has not returned my email. (I think it might be too old a model for them.)
Any help would be appreciated.
Frank</span>[color:#006600]</span>
vivdownunder
Frank, I haven't got the answer, but Lucas UK these days is a company supplying repro components. The original Lucas that would have made your coil went bust long ago.
Viv.
lbcs_r_fun
6TTR3A said:
<span style="font-size: 11pt"><span style="color: #003300">[/color] but I've got 6.7 ohms across the secondary, which no one I've talked to can confirm or deny is OK.
You have the correct Lucas coil for the car, but 6.7 ohms sounds like a shorted coil. I'm thinking the secondary should be several thousand ohms.
Does this coil produce a healthy spark with the stock points system?
Are you sure you don't have your meter on the ohms times 1000 scale?
I have a few HA-12 coils and will check later today.
T
dklawson
I agree with the above. How is your meter set up and how are you measuring the secondary resistance?
6TTR3A
6TTR3A
<span style="font-size: 11pt"><span style="color: #003300">It's no wonder you're confused. I've got to start proof-reading my posts!! I MEANT 6.7K ohms across the secondary.
My coil is presently on the bench. Primary is measured CB to SW and secondary SW to HT When I removed this coil from the car 5 years ago, it worked fine. The coil I have in there now has too much resistance (4.1 Ohms across the primary) to be compatible with a Petronix </span></span>
TR3driver
Great Pumpkin - R.I.P
Higher than 3 ohms is not a problem for the Pertronix; and the coil should work just as well with the Pertronix as with points.
But I'd go with the 3 ohm anyway, as the higher primary resistance may present problems with weak spark at high rpm (when there is less time per firing for the inductance to charge).
Secondary resistance is only a very rough indicator of coil condition. Anything between maybe 3K to 15K should be fine.
But that still doesn't prove there isn't a problem. The acid test is to hook it up and run it.
poolboy
From the Pertronix box:
lbcs_r_fun
OK That sounds more like a believable value of secondary resistance! :yesnod:
T
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
Lukens TR2/3/3A TR3A coil. Correct resistance? Triumph 6
A TR2/3/3A Correct Coil for petronix ignition tr3A Triumph 2
T TR2/3/3A On TR3A what gauge wire from fuse box to coil? Triumph 17
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
angelfj1 TR2/3/3A Lucas Ignition Coil for TR3A Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
