TR2/3/3A TR3A Battery
RonR
Folks,
What is the recommended battery series and size for a TR 3A?
Yes, I hope to have this car started soon after 2 years of watching it sit in my garage.
Thanks,
Ron
I use a Group 24 (from WalMart) though there is room for a wider battery in that box.
TRA's guide give the group 27 as the original size. A sidescreen car looks good with that size since it fills the battery box very well.
Lou Metelko
Auburn, Indiana
Lou, does that mean that Triumphs deliverd in the US had US-spec batteries? Like so many other things, Lucas used a different set of standards back then. Plus the TR2-3 workshop manual lists two different sizes of battery ...
My 1958 TR3A was delivered new to my S-T dealer in Montreal with a huge size 27 Lucas battery with a tar top and the links exposed. Just like the three replacements I bought over the past 20 years from Antique Battery Company in Hudson, Ohio.
See the last one taken in 2007.
If you have a nicely painted fire wall get a sealed OPTIMA. It will save you a heart ache or two. Get another "show" battery if you need it.
Those "Show Batteries" like mine have been there for every-day use as well as for shows for 20 years. And I never had a plastic insert battery box like everone uses. These "Show Batteries" are like the original ones and are now available "sealed" in the latest info I have right from The Antique Battery Company.
I'm with Geo; Size 24 from Costco, which is a Johnson Controls battery...
(positive ground, too).
I became a big fan of AGM batteries (which is the same as the Optima) because of my experience with my '92 Miata. I changed the original AGM that was in the car in 2009. :cheers:
I really like Don's battery -- but am probably too thrifty to go that route. The W*M version cost $39.77 (6 years ago).
I do not use the tray and haven't seen a problem so long as I have the control box properly adjusted. Thoughtfully STC provided that brass tag just above and behind the battery as a sacrificial indicator of over-charging.
