Just tried installing the "battery cut-off switch", Moss 145-795. Seems to be good quality, but sure installs weird.
It's sized for the negative post, so can't go on the woven cable if you have a positive ground system.
Installation causes the negative cable to end up "vertical" instead of horizontal at the battery end.
With the positioning of the cut-off switch on the negative cable, the cable needs to go between the battery and the battery hold-down "stump". That's really tough to use - as you can't pull the disconnect the way it's set in there. Seems more trouble to try to disconnect the switch than to just loosen the original battery clamp nut.
Has anyone used that disconnect switch on a TR3A?
Thanks.
Tom
Thanks.
Tom
