PeterK
Busy weekend.
Got the GM 7127-3 alternator installed in the 3A today. After removing the generator, I pulled the old bracket to drill the rear hole to 3/8". I used 2 - 3/8-24 bolts and a grade 5 coupler with jam nuts to span the generator bracket. Some said to get a 7" bolt and I would have used this with a spacer, if I could find one without mail ordering the thing. Funny, but nobody locally sells longer the 6" and then not grade 5 or 8. Also if you use a long bolt, you must install it in the bracket before you install the bracket or the exhaust pipe will be in the way. Using the original adjusting bracket required a 1/2" spacer on the waterpump mount to get the pulley aligned properly without having to flatten the adjusting bracket for pulley alignment.
I gutted an old regulator to use the external terminals and preserve some degree of originality. The cover was in 3 pieces but after JBWelding, sanding and Krylon fusion, it looks very nice. Can't say "new" because the cover is bakelite which is a dark brown, semi-flat finish and now is black gloss. But still nice looking.
Wiring was kind of a pain because I had to extrapolate what I needed to do from the information that I gleaned from the web. Once I figured out what DMI was trying to do, it was easy to wire. His instructions are a good cookbook but I prefer to know what I'm doing before I attempt it. After installation, my idiot light works as before, ammeter works. I wired a direct feed from the post on the alternator to +side of the starter solenoid (also newly replaced). This sends the power directly to the battery instead of though the dash. I found it interesting that at 500rpm idle (just redid the jets and floats earlier this week so my idle is nice and smooth this low!), the dash light was on until I blip the throtte and the exciter kicks the alternator in. I think this is a SI alternator for low rpm kick in but I guess not 500rpm.
The hockey tape was a good tip for wiring harness cover too. Thanks to whoever posted this.
