<div class="ubbcode-block"><div class="ubbcode-header">Quote:]going to pick them up sunday. for the spair i will just use the factory iron wheel . cant see it anyway[/QUOTE]<span style="font-size: 11pt"><span style="color: #003300">The odds of you having a flat are slim these days, but if you do, your steel wheel isn't going to work unless you remove the splined hub. (And then I'm not sure the steel wheel will fit on the shortened studs). Find a 48 spoke wire wheel, mount a 165 15 tire & you'll have a spare that fits in your spare hole and will get you home.
Frank </span></span>
