I am going to get wire wheels for my 56 TR3. I like the look of the 72 spoke Dayton wheels, any issues with the 5 in width versus the 4.5? Anyone using the Revington spacers in lieu of chopping the bolts?
I personally prefer the look of the 60-spoke, but then I also think painted look better than chrome on a TR3. To me a 72-spoke chrome says 'Jag' (not that there's anything wrong with that). Just a matter of personal taste/opinion.
I do use the spacers and often switch the wires & steel wheels between the 2 TRs. Only takes about a half hour and gives a different look. If you are planning on staying with the wires all the time then you should really consider shortening the studs though I have had no problems using the spacers for 5 years & 10s of thousands of miles.
P.S. I obtained my spacers locally at a hot-rod shop. They are 6mm (1/4") -- one well-known source said to use 9mm but clearly that would not work.
Thanks for the input. The only reason I like the Revington spacers is they are made for the car and don't have a universal oblong hole.
I was actually considering getting the wires powder coated an off white/light tan for my red car with tan interior.
Like the idea fo being able to switch back and forth on the wheels
