This is two follow-up questions directly related to Greg's question. I have not confirmed this problem, but I highly suspect it.
1. What if my wipers run fine when the engine is not running, but will only make two passes (over and back, over and back), then stop, when the engine is running?
(I think that this is the case, but I am not going to start the engine to confirm this until I have a fellow club-member with me. I do not want to do any more damage, until I find out what is wrong with the engine.)
2. Can the electric motor be lubricated?
I was tickled to turn on the key, pull the switch, and have the wipers run on and one. However, there is a pretty loud "running noise" coming from the electric motor, not the gearbox. Any explanations for this? Lubrication? Something else?
Thanks in advance. Greg, I did not want to steal your thunder, but I think that our problems are pretty closely related.
