TR2/3/3A TR3 Windshield size question
griff
OK, I am very corn-fused. To be sure my new windscreen install goes without problems/breakage, I opted to assemble my frame without the glass, put tape over the frame and lay the new windshield on top to get a feel for spacing. To my amazement the glass barely covers the opening on the sides as it nears the corners.
IS that right?
There are spots where there will be less than a quarter on an inch actually in the frame and I am not sure that is sufficient if the glass shifts at all.
Does someone have a loose windshield and frame they can measure?
(My old one had a severe crack and broke up on removal).
At the widest point, across the bottom, my glass measures 44" and the frame (screwed together measures 43 7/8 ID That's not much and it seems that it could shift that little bit and come out.
Am I missing something or is my new windscreen too small ?
(I believe if I were to let it drop all the way in bottom frame piece the top corners may not be in frame).
All suggestions welcome.
I do apologize for being so wordy.
Thanks
Griff
FWIW --
I have a spare windscreen glass and at the bottom/widest point it also measures 44".
The frame on the car measures 43 13/16" at the bottom of the opening.
We had a few glass issues where we thought the glass rubber was too big only too find out the the rubber gets installed on the car first then the glass is installed into the rubber. Very different from a window/rubber combo that you wrap a rope around the outside groove and rope set it in place etc.
When it comes to glass it never hurts to call a professional to install it. They tend to have more tips and tricks that insure a leak free backed by a warranty job.
