TR2/3/3A TR3 Windshield-[screen]? Holder on'r thingy remove
Beerzz
Ok, I give....Im trying to get the windscreen brackets off the body without damaging it, or the screws but it is going to take more than i'v thrown at it?
I could use some well earned advice Thanks
Ben
Moseso
I used one of those "hit it with a hammer" impact wrenches. Worked like a charm. I think you can see the caged nuts, up inside the scuttle, if you need to soak 'em in rusted-thread loosener -- or if someone needs to keep the nuts from spinning with a vice grips.
TR3driver
Great Pumpkin - R.I.P
apbos
Did the same as above (got the hammer at Sears (a great tool). The PB Blaster can be sprayed in from the backside (at the schuttle) and let it do it's work for 24 hours.
Paul
B
Beerzz
Thanks, I'm soaking them down now and I have an impact driver. BAM!
Tinkerman
Yep, I favor the hand impact driver and a BFH. Worked for me on a number of occasions but let soak in PB Blaster or Kroil as suggested for about 24 hours.
Good luck, Tinkerman
B
Beerzz
Thanks
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
N TR2/3/3A TR3 windshield Triumph 2
N TR3 Windshield FORUM Navigation Questions 0
Lbp TR2/3/3A Question about TR3 Rubber Windshield Seal Triumph 9
Tinkerman TR2/3/3A Windshield glazing TR3 A 1960 Triumph 7
D TR2/3/3A tr3 windshield Tenax fasteners Triumph 2
luke44 TR2/3/3A TR3 Windshield Rebuild and Assembly - Step by Step Triumph 20
luke44 TR2/3/3A TR3 Windshield Stanchion Short Screws Long Screws Triumph 2
6 TR2/3/3A TR3 windscreen/windshield glass Triumph 5
M TR2/3/3A My own TR3 windshield question? Triumph 5
J TR2/3/3A TR3 windshield angle and body shims Triumph 11
O TR2/3/3A TR3 Turn Signal Retrofit / Windshield Screws? Triumph 7
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
S TR2/3/3A windshield wipers tr3 Triumph 1
T TR2/3/3A TR3 Windshield washer pump Triumph 14
B TR2/3/3A TR3 Windshield Wiper Tubing Triumph 5
Marvin Gruber TR4/4A Windshield motors TR3 & TR4 Triumph 2
AngliaGT TR2/3/3A New Windshield for TR2,TR3 $150 Triumph 2
S TR2/3/3A windshield post 60k tr3 Triumph 10
O TR2/3/3A TR3 Windshield Glass Replacement Triumph 2
mountainman TR2/3/3A TR3 Windshield Center Support Triumph 1
G TR2/3/3A TR3 windshield corner finishers Triumph 4
O TR2/3/3A TR3 Windshield Replacement Triumph 4
G TR2/3/3A TR3 Windshield size question Triumph 2
G TR2/3/3A TR3 windshield isntall Triumph 11
G TR2/3/3A TR3 windshield assembly sequence Triumph 9
mrv8q TR2/3/3A TR3 Windshield Stanchion Q Triumph 6
D TR2/3/3A TR3 post 60000 windshield stanchion guide plates Triumph 5
M TR2/3/3A TR3 Windshield Frame Triumph 2
bmurphy7369 TR2/3/3A TR3 Windshield Stanchion Guide Plates? Triumph 22
G TR2/3/3A TR3 windshield disassembly Triumph 3
