TR2/3/3A TR3 Transmission Oil Capacity
jsneddon
I'm going down to Pep boys this afternoon to get some gear oil for the transmission and I forgot to grab my manual on the way out this morning.
Does anyone have the capacities table handy?
Simon TR4a
From memory, and if you have overdrive, 1.8 litres. (In US, 3.8 litres is a US gallon, we're metric up here!)
Simon.
Alan_Myers
Hi Jim,
Simon is close.
TR3 is same as the TR4 I'm sure, which is:
Non-OD, 1.8 pints (US, not Imperial)
OD from dry, 4.2 pints
OD drain & refill, 3.3 pints
Source is the TR4 factory workshop manual.
Cheers,
Alan
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
P TR2/3/3A TR3 Transmission oil Triumph 13
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
S TR2/3/3A Tr3 transmission oil Triumph 4
T TR2/3/3A Proper oil TR3 Transmission Triumph 3
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
Moosca TR2/3/3A TR3 Overdrive Transmission Verification Triumph 5
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R TR2/3/3A TR3 A Transmission rebuild Triumph 5
charleyf TR2/3/3A Transmission numbers on a TR3 Triumph 7
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
T TR2/3/3A Is CT52431 a TR3 Transmission serial ? Triumph 4
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
Russ Austin TR2/3/3A TR3 Transmission question Triumph 8
mgbmedic TR2/3/3A TR3 Transmission Tunnel Triumph 8
O TR2/3/3A TR3 Transmission Removal Triumph 2
RedTR3 TR2/3/3A TR3 Transmission Differences Triumph 27
RedTR3 TR2/3/3A Removing TR3 OD transmission Triumph 5
M TR2/3/3A Draining and refilling TR3 transmission with OD Triumph 23
M TR2/3/3A Metal transmission cover color for TR3 ??? Triumph 9
T TR2/3/3A TR3 transmission cover - supposed to be metal? Triumph 5
Moseso TR2/3/3A TR3 Transmission noises Triumph 11
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
CCURTISS TR2/3/3A TR3 Transmission Tunnel Sealant Triumph 7
CCURTISS TR2/3/3A TR3 Transmission Questions Triumph 14
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
S TR2/3/3A tr3 transmission Triumph 2
S TR2/3/3A tr3 transmission front seal Triumph 3
mcguijo TR2/3/3A TR3 Transmission Blues Triumph 16
T TR2/3/3A Hole in transmission bellhousing TR3!!!! Triumph 5
R TR2/3/3A TR3 Timminge Triumph 5
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
