TR2/3/3A TR3 temp sensor hole plug?
chrissmith
Hi all,
Any suggestions on what I can use to temporarily plug the threaded hole for the temp sensor on a TR3? I do not have an original, so I would like to plug the hole so I can work on some debugging while I search out a proper replacement. Will a TR6 sensor fit?
Thanks
HerronScott
I believe that I've seen some suggestions on here to use an early TR4 electric temperature gauge and sending unit as those gauges have the same design as the TR3 gauges. (curved glass and fully exposed needles).
Scott
TR3driver
Great Pumpkin - R.I.P
Another possibility is a cheap 2" mechanical gauge from your local auto parts. The Sunpro I picked up fit perfectly, except I had to connect the wire for the light into the dash lights.
I think this is the same gauge at Amazon (got mine at Pep Boys):
https://www.amazon.com/Sunpro-CP7975-Mechanical-Water-Temperature/dp/B00029JXQ6
If you go with the TR4 gauge, you'll also need a voltage "stabilizer" or otherwise it will read high (and vary with whether the generator is working or not).
C
chrissmith
Thanks guys. I picked up a guage assembly at Napa today for 17 bucks. Never would have guessed an auto parts store would have something for this car, let alone in stock and affordable.
luke44 TR2/3/3A TR3 Water Temp Sensor Installation Problem Triumph 37
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
G TR2/3/3A TR3 Temp gauge Triumph 2
6 TR2/3/3A electric coolant temp gauge in TR3... Triumph 6
tinman58 TR2/3/3A TR3 temp gauge Triumph 13
T TR2/3/3A TR3/4 elec. temp gauge Triumph 6
Perrymip TR2/3/3A TR3 Sudden Temp Jump Triumph 7
K TR2/3/3A TR3 Temp Gauge Upgrade? Triumph 5
K TR2/3/3A Reliability of TR3 Temp Gauge? Triumph 16
JohnnyMead TR2/3/3A TR3 - Routing the Temp Guage Tube? Triumph 5
luke44 TR2/3/3A TR3 Water Temp Gauge Core Triumph 14
mountainman TR4/4A TR3 - Tr4 Temp Gauge Triumph 5
TRclassic3 TR2/3/3A TR3 temp gauge Triumph 15
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
M TR2/3/3A TR3 Temp Gauge Triumph 27
F TR2/3/3A TR3 Seats and Temp Gauge Triumph 5
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
