Can anyone tell me what type of lubrication, if any, should be put on both the flywheel end of a late TR3 starter (non-bomb type), and inside the cap on the opposite end? Thank you.
Thanks Randall. So on the brush end, its OK to spray a little bit dry lube on the tip of the shaft that turns as long as you wipe off the excess? Inside the cap that fits over the shaft, there appears to be some old dried up white grease when I assume doesn't belong there.
