Got_All_4
This is getting old. 5th weekend in a row and don't have the car on the roadyet. Last night I finished putting the hubs on after new axal seals and didn't make it out of the driveway. As soon as I touched the gas the car would die. Traced it to 2 plugs not firing correctly. Pulled the plug wires off (it's always happens to # 3 &4) and the terminal inside the 90 degree plug pulls out and stays on the end of the plug. As soon as that happens your done. The wire inside the 90 degree cap is spring loaded and there is no way to get the terminal end back in and stay in because it was molded around the splines when it was made. I did come up with the bright idea to drill a hole in the end of the cap and push the spring loaded wire back then push in the terminal. When I was successful with that the spark would short circuit through the hole. Of course when I pulled the wire off the terminal was stuck on the plug again.
My question is what other plug wires can I use with the 90 degree terminal in place of these wires. This is the 3rd set I've been through in the last 5 to 6 years. Please advise.
