Okay, I'm sure there's a really easy answer for this, but how exactly do you remove the shift lever from a TR3 transmission? Neither the factory manual nor the Clymer's manual provides much insight other than saying "unscrew it." Is that really all there is to it? Double-nut the shift knob threads and have at it? Does the "Cap, change speed lever" need to be removed first? There's a small bolt at the rear, and a through bolt with a nut. I've removed both of those, but still can't quite see how to remove the shift lever.
Thanks in advance.
Thanks in advance.
