I've done some mods to my 3 engine but it seems to run rough thruought the range other than when I get into the higher rpms.Have done plug checks and found the plugs black and sooty so I leaned out the carbs a couple flats but havent tested the car yet for improvement. I read somewhere that if you put a header on these cars you should change the SU needles to "RH"anyone heard this.....but wouldn't that just worsen a running rich problem? The engine is freshly rebuilt with a couple hundred miles on it.It has a mild street cam and I realize that a somewhat rough idle is standard for a modified cam. The car has a header and the later TR4 curved intake manifold.The carbs have been rebuilt and Petronix ignition installed.I have opened up the valve gap(I'd have to find a previous thread here to find what I set that at) I'm in Winnipeg so its still winter here and cant get the car on the road yet but I'm interested in any feedback as to how to proceed to get the engine to run smoother(if its not just the cam). Cheers Karl
