I am really disappointed in myself because I cannot track down the problem with my TR3's right turn signals not working. Here are as many of the facts as I know them.
The right signal DID in fact work just the other night and I know because I did a victory dance.
The left signal works like a charm. I have switched bulbs from left to right. I have switched flashers though I switched to one that did not work at all so that might be a non starter.
When I pull just one stop on the light pole for the parking lights, the separate lights that the turn signals use, both front ones work but neither one of the rear ones work. Is that normal? It makes me think that the wire going to the front right at least is good. The back right is the only light I have not seen working. I just replaced my my trafficator switch with a single pole double throw toggle but it was not working before I replaced that. I think that I have a pretty good understanding of the schematic. The green/white wires are the ones that I am concentrating on. I see only one wire going to each of the rear signal lights.
My turn signal indicator, the yellow light on the right hand of the dash, is not working even when the left turn signal is. It has always worked before. Is it possible that this light not lighting means something important? Is it possible or probable that a flasher unit would stop working just on the right side? Is there a continuity test I can make on the flasher without having to get a new one? Is it possible to get a generic flasher at my local auto parts place?
Any help would be much appreciated.
Thanks very much,
Jim Lee
1959 TR3a
Thanks very much,
Jim Lee
1959 TR3a
