My trans (Std 4 speed - no OD) on my 59' TR3 is leaking out of the rear of the trans. I "assume" it needs a new rear seal. In looking it over it appears that there is not enough room to replace it from the bottom. Removing the tunnel and replacing it from the top would be quite a problem too because I made sure that the tunnel would not leak when I had my engine out last year. A combo of caulking and fiberglass made sure of that. Thus, removing the tunnel would be quite difficult. Is it possible to change the seal from the bottom or do I have to pull the trans, or is there another mechanical option? What about the trans seal junk they sell? Thanking you in advance for your valued input ........AL
