TR2/3/3A TR3 oil leak
lemon lover
Hello everyone. I have been daily driving my TR3 to school everyday and I have noticed it leaving big puddles behind in the parking lot. Also there seems to be oil leaking from underneath the head. Any ideas about how I can fix this?
Underneath the head ?
Can you pinpont the exact source location ?
You'll have to know that in order to fix it .
Try placing some old cardboard under the car to try and see the leak location. There are also dies you can add to the oil and find with a black light.
Two common spots to check. TR3's tend to leak from the gasket that holds the engine oil pan at the bottom of the motor. Also clean up the area around the valve cover gasket and check back there after a drive to see if that is where it's leaking from. There are other places as well. The cardboard is a good idea.
Sorry for the delay. It seems that the rear main is leaking because a large amount of oil is leaking through the space between the engine and transmission. I have already cleaned the back of the motor off and the valve cover looks fine but there is oil on the lower half of the head where it sits in front of the firewall.
If you did not know, the crankshafts on these engines use a cut in place scroll on the back of the crankshaft for the seal. The scroll throws the oil back into the engine creating the seal only when the engine is running.( do not park on a steep hill or the oil can get out--i have heard)
There is a seal in the back, but it is not the rubber seal one thinks.There are 2 aluminum pieces that have small groves cut into it to divert any little drops of oil back into the pan by way of the spout in back of the block.
Try lowering the oil level a half quart. Like Steve says, the TR3 does not have a "positive" seal for the rear crank. The scroll seal only works when the engine is running. If the oil level is too high, it will leak out. These cars are funny like that...the radiator does the same thing. If you over-fill it, it will spit it right back out to the level it "likes".
Yes it’s my experience that my 3a “likes” a lower level of oil where it becomes static any more and it gets rid of the excess. So I filed a new “normal” level on the dipstick.
I’ve had many triumphs, they all leak
I do lay cardboard down, I also rebuilt the engine
No new conversion was around for the rear seal back then, I’m 72 , still have a TR 4
Its just a British thing , I kinda like it
The angle in the parking space can put the oil to the rear of the motor. causing
in effect an "overfill" situation. Back into the space if needed.
Mad dog
My engine head was wet with oil. I glued a silicone seal to the valve cover and that cleaned that area up. I also have the rear main seal issue. I am losing much more than a few drops. My engine needs to come out for installing the seal that rides on the smooth part of the crank, without having to grind the crank as some earlier seals require.
I have recently replaced the front crank seal. I am sure the one I took out was original. I bought replacement seals from three suppliers to install the best of them. The three looked really flimsy in comparison and together weighed less than the seal I removed.
As I say, it is the rear main seal next and that is an engine out job, unfortunately.
Good luck
And if you do pull the engine and replace the rear main seal, and after 3 months it’s not leaking again, you’ll be a wizard. I use the viton seal one from Mad Marx. It’s good. But no matter how careful I am, I still get a leak. Don’t forget, a small amount on the floor looks like much more. If I were in school, and I sure remember when I drove my TR to school, I would not attack an engine removal unless I had a good 4 weeks to spare. Once you start, you’ll be into things like the camshaft, the crank, the bearings. Unless you’re lucky not to be afflicted with Shipright’s Disease.
