CraigLandrum
Disassembled, cleaned, and reassembled the speedo last weekend and verified smooth operation with drill run in reverse. Bought and installed new cable from Moss. Worked fine, but after 5-10 minutes it began to make an intermittent squeal - a few seconds of quiet then a second or so of squeal, and after a mile or so the squeal periods seemed to get longer. At that point I disconnected the cable. The speedo appeared to work OK even when squealing, but I thought it best to be cautious. With a hand on the cable, the squeal coincided with increased cable vibration, so I'm guessing that the inner spring cable could use a liberal application of lube. Is lithium grease what I want to use and is it likely to solve the problem?
