Forgive me if this has been asked before, but I couldn't find anything using the Search function. I'm looking for some tips on removing the brake and clutch master cylinders from my 1959 TR3.
I have the original service manual, but it's pretty sparce other than telling you what bolts to remove. Got the brake lines disconnected, the reservoir removed, the top mounting bolt removed on both, and the clevis pin removed on the brake. What I can't seem to manage to do is the get the clevis pin off on the clutch side -- no way to get any sort of screwdriver in there that I can see. Do I need to remove the wiper motor? Also, can't seem to get anything to get at the lower master cylinder mounting bolts. Tried various extensions/elbows/etc. to no avail. Looks like there's some sort of bolts coming up through the pedal box that are interfering.
Any tips/secrets?
Thanks.
Mark
Any tips/secrets?
Thanks.
Mark
