mountainman
I tried searching this but came up with leaking tops, antifreeze, radiators but no oil pans. I googled it also and did find a nice bit that Don Elloitt wrote but don't know if I can do all he did to stop the leaks. He put a metal gasket so to speak, welded to the oil pan to stiffen it up. I did buy a silicone valve cover gasket and it worked very well. Does anyone know if the silicone oil pan gasket is available? Or any other things to do that might fix the problem.
Thanks
Greg
Thanks
Greg
