TR2/3/3A TR3 Heater Coolant Flow Direction
RedTR3
I would like to find out the direction of coolant flow to the TR3 heater: Is it out of or into the valve on top of the cylinder head?
Thanks,
Tim
newmexTR3
Hey Tim,
It flows out of that valve and into the cockpit, then out through the firewall on the driver's side.
Cheers,
Gavin
TFB
Have any of you guys repalced the manual heater valve with a vacuum operated valve,or electric solenoid valve to control the hot water from the cockpit so you could have some defrost if needed,even if heater valve was off for summer,with out popping the hood?
just a thought,
Tom
angelfj1
Tom: That seems like a lot of trouble to go through for occasional use. If you close the heater doors, open the vent flap and turn on the blower which should clear your windscreen. Alternatively during the warm weather maybe just crack open the valve a bit. You can fit a TR4A heater control valve and cable control also.
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
parkerg1 TR2/3/3A TR3 Heater Triumph 10
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
M TR2/3/3A TR3 Heater Triumph 34
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
M TR2/3/3A TR3 heater install picture needed Triumph 33
Lukens TR2/3/3A Would you sell your TR3 heater? Triumph 18
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
Russ Austin TR2/3/3A Attempting to install a heater in my TR3 Triumph 39
M TR2/3/3A Heater removal in TR3 Triumph 13
H TR2/3/3A TR3 heater options Triumph 9
ekamm TR2/3/3A Tr3 heater valve Triumph 12
T TR2/3/3A TR3 heater pipe bracket Triumph 6
S TR2/3/3A Repairing a tr3 heater? Triumph 14
S TR2/3/3A tr3 heater Triumph 7
af3683 TR2/3/3A TR3 Heater Hoses Triumph 4
D TR2/3/3A TR3 heater reinstall problems Triumph 4
RedTR3 TR2/3/3A TR3 Heater Question Triumph 8
luke44 TR2/3/3A TR3 Smiths Heater Plate Triumph 3
S TR2/3/3A Tr3 heater wirer Triumph 8
M_Pied_Lourd TR2/3/3A TR3 Heater Finish Triumph 8
S TR2/3/3A heater attaching piece tr3 Triumph 4
newmexTR3 TR2/3/3A TR3 heater hose install Triumph 4
Tinkerman TR2/3/3A Unknown Part TR3? Heater Bracket? Triumph 5
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
Got_All_4 TR2/3/3A TR3 heater valve is leaking like a sieve Triumph 3
newmexTR3 TR2/3/3A tr3 heater vacuum lock? Triumph 2
S TR2/3/3A TR3 pipe leaking [housing to heater] Triumph 3
Got_All_4 TR2/3/3A My TR3 heater fan switch is broken Triumph 8
T TR4/4A TR3 / TR4 heater question Triumph 2
M TR2/3/3A TR3 Heater Core PSI Triumph 3
Geo Hahn TR2/3/3A TR3 Heater Alternatives Triumph 11
J Spitfire Spitfire heater upgrade to TR3? Triumph 7
PeterK TR2/3/3A TR3 heater part Triumph 0
