aaronclark
Some of you may have saw my post about the engine in my almost road-ready TR3 that was leaking oil on its first start up, well when I dropped the oil pan to look at the rear main seal i saw some coolant dripping off the crankshaft. I pulled the valve cover and found some coolant sitting on top of the head as well. I only ran the car about 15 minutes to adjust timing and carbs and stuff, but in doing that I managed to overheat it.
Well, i realized that i didn't add enough water so i topped it off and it cooled right down and stayed at 165 or so. I thought maybe the head gasket had just gone bad from sitting dry(it may have been rebuilt 4 or 5 years before actually running). I have a new head gasket but I am going to try re-torquing the head before i change it. So I have a couple questions:
1 how much damage could i have done by overheating it on its first start
2. are there any other places the coolant could leak past
3. what should i do to break in properly once it is back together(this could probably be a thread of its own)
Thanks all,
Thanks all,
