Finally have a new spring and plunger to end the annoying shifter rattle. does anyone know a good way to install the plunger and spring without the whole works disappearing into the black hole void where all small British parts disappear into? I'm assuming the gearbox cover has to come off so you can get your fingers between the top cover and trans.The new spring exerts quite a bit of pressure and holding the plunger onto the spring and compressing it could be problematic? I wonder if a flat blade screwdriver holding the works in and lowering it down....gently pulling the screwdriver out without popping the plunger would work? anyone been there and done this? thx CK
