Thanks for the MG site link Dave. There seems to be some good information there. Also appreciate the links to repair places.
Last year the speedo started bouncing a lot. It would bounce to a speed well above the car's speed and stay there. Increasing the speed of the car would cause the needle to stick at an even higher point. When stopped I would have to tap the glass to get the needle back to zero.
I took the unit apart following Geo's link information and generally cleaned things up. When finished the speedo worked nicely and didn't bounce or stick. I didn't put any lube into it and wonder if I should have.
The last few times that I drove the car the speedo was up to its old tricks and getting worse as I drove it. On Sunday it was particularly bad and started squealing too. Then everything was quiet and it had stopped working.
I haven't had a chance to look at it yet, but now that I think about it I'm thinking the squealing was from the cable and that it may have broken when everything stopped.
Hopefully I will get time to look at it on Wednesday night.
Neil Rogers
Edmonton, Alberta
1961 TR3A
1980 TR8 DHC
