Hi tr3 people first let me tell you my set up. I have stock S.U.s and an A.C. fuel pump so the vehicle is stock except for a fuel filter back by the tank. What happened is I was driving up Chinook Pass in Washington (5500ft) and was about 100 yards from the summit and the car starts fading out. I pulled over shut it off then started it back up figuring the bowls had run dry. The car starts up but fades out again. I thought oh this must be connected to the mountain, but I kinda panicked. Perhaps if I had used some patients the problem might have gone away. BUT I undid one of the top on bowls and it was just about dry, so I blew the needle out and thought well I will try and start it. It did not start. Then I undid the fuel line at the float bowl and cranked on it. The gas spurt was just kinda whippy and I could not tell for sure if it was really working.
It was becoming unfun. The gal with me said maybe that thing (the pump) is clogged, so I thought it might be the little brass screen in there is clogged, plus I could show her how cool I am (was) by popping it out. Well, when I got the bowl off the pump and looked at the screen it was ok. However, the rubber ring and somehow enlarged and it would not go back in place. Then it dawned on me that I had put a fuel filter in the back in the trunk. So back to the trunk I go with my very small tool kit. I could remove the filter, but what would I put in its place. Karen had an ink pin, so I used that, but the plastic started getting sticky. It just looked too dangerous, so after asking the nice people who stopped if the had a piece of 5/16 pipe about 3 inches long. I thought well I could cut off the little nub on the end of the old fuel filter and stick that in the gap. I did and it worked. The story goes on.
Back at the fuel pump the rubber would not go in) I do not know why it expanded and would not shrink) I must have been afraid of trying to cut it down. But after a while and being stoked with manic adrenalin I starting stretching vinyl tap over the lip of the bowl moving it around and it worked. By this point, I had basically given up and figured the pump was dead, but that just did not feel right. I keep cranking on the motor as we set and waiting for the wrecker. And then like magic a little spurt came into the bowl. It was funny; Karen got all exited like it was Christmas. I thought this thing is going to run. It started and I drove it home with the blessed Haggerty Insurance wrecker coming up the mountain to rescue me. I was able to honk at him and he turned around and we worked it out in Eatonville.
Anyway after that long context here are some of my questions. Should that stock fuel pump have been able to adequately pump the amount of fuel needed going up a mountain on acceleration with no problem? Could the fuel filter in back slow down the pump even if it was not clogged? And finally does the class bowl have to be sealed up on the pump for the pump to work.
Thanks George
Thanks George
