Wanted TR3 Front Float Bowl Lid SU H6
frankfast
Looking for the front float bowl lid for an SU H6 carb. One of the brass fittings for the fuel line connection is cracked and bent. Moss doesn't sell the front lid.
Are you talking about the early lid, or the later one? If it's the later one, those lines can be pulled out and replaced. I forget offhand what I used for replacement, might have been ordinary "refrigeration" soft copper tubing.
Or just buy a new one from TRF 506728
The Roadster Factory. 506728 is the factory part number for the later front float lid. (TRF uses the same numbers.)
Just received a message from The Roadster Factory that the float lid is no longer available. So, does anyone have a spare?
