TR2/3/3A TR3 fan pulley hub
TRclassic3
Anyone happen to know the correct speedi sleeve to use and the best source?
TIA
I believe I got P/N 99175, which fits a 1.75" shaft and is .875" wide overall. But my local NAPA store (Gardena,CA) had 99174 listed in their catalog, which is the next size narrower.
However, the NAPA in Torrance, CA (closer to where I work) only carried a substitute line of sleeves (FelPro I think), which didn't cover the TR3 (even when looking up by size). I guess not all NAPA stores are created equal.
I used 99174 and it worked fine as well. Suggest Rockauto, they have National, SKF and Timkin sleeves and you can find them most times for less than $30 with shippping factored in.
