TR2/3/3A TR3, Failure to Proceed
MGTF1250Dave
Aloha All,
Driving to work this morning my TR3 failed to proceed. The engine died and I was able to move to the shoulder without incident. The starter turned the engine over rapidly but it would not start. I checked the fuel side and the pump is working well and fuel to both carburetors. The problem seems to be on the ignition side and I suspect it is either the coil or a broken wire in the low tension circuit. The points are opening and closing as the distributor turns. A friend help me tow it home and I work on it tonight after work.
I had only a screw driver and a crescent wrench (adjustable spanner) so I was limited in trouble shooting electrical items.
Check your rotor I have had some of them crack and short killing the engine.
Don
And look to the points "carboning". Run an emery board thru 'em.
I now carry a spare rotor and cap, because I've had 2 rotors cause the car to die. I also carry an extra spark plug, plugged into a wire. That way I can plug it into the coil, check spark, plug it into the cap, check spark again and know the rotor is shorting -in a few minutes. -without tools or getting my hands dirty.
You probably have it fixed by now... what was it?
Aloha All,
Thanks for the advise. It was the coil and I had a spare, a lucas coil dated 12/58 on the bottom. It took about an hour to diagnois an put in the replacement coil.
I've decided to carry a few extra tools, a test light to check electrical circuits and a few more wrenches and screw drivers.
Hi Dave,
Glad to hear your Fix was a simple one. Typically they are.
I used to have a `55 TF. I went to a Morgan meet & my car was spitting and sputtering all over the place.
I had "Nothing" on me! No spare plugs, rotors, caps etc. not even a phillips or flat hd. screwdriver! "DUMB"!
After a Morgan mech. replaced the plugs for me; My Tool Box got filled with all the necessary "Emergency" accessories to include a spare Belt (You never know).
Have Fun,
Regards, Russ
I think that would be under your 50 year warranty!
Aloha Russ,
You may be right, the old coil that failed was stamped 5/58 on the bottom. Since the failure was on 4/30/2008 maybe it would fall under the 50 year warrant, but if it is prorated I would get much.
MGTF1250Dave said:
...I've decided to carry a few extra tools, a test light to check electrical circuits and a few more wrenches and screw drivers.
When you consider how often sudden roadside failures are ignition related, and how the entire ignition system is just a handful of parts -- it may make sense to carry a spare of the whole thing.
I put a spare loaded dizzy in the center of the spare tire.
But since I've never been stranded by a bad coil, and a usable coil can be had at any FLAPS (even a modern HEI coil will get you home), I don't bother carrying a coil.
TR3driver said:
...and a usable coil can be had at any FLAPS (even a modern HEI coil will get you home), I don't bother carrying a coil.
That's the case in Sunny SoCal... but when the coil decides to die in, say, Why, Arizona or somewhere just outside Wikiup -- a spare coil is very welcome.
I've actually been to Why (tho I don't recall why :G)
And I'm confident that I could source a suitable coil there. Almost any car or small truck from 1950 through maybe 1990 would serve as donor; and I saw several candidates sitting around.
Sure, it could happen, and I'm not saying there's anything wrong with choosing to carry a spare coil. It's just not my choice of item most likely to strand me.
Somewhere out in Texas there is a sign on I-10 that reads "Next services 104 miles". I've passed that sign, while driving a TR3 that I had just bought, sight unseen (and had a friend pull out of it's resting place in a cornfield).
