PatGalvin
Hello All
On the bottom of my TR3 engine, behind the front plate under the front main crank bearing, the aluminum Front Sealing Block has stripped threads for the hole in the bottom middle, where the oil pan fits up and screws in (one screw). Can anyone tell me the correct screw size and thread pitch? Mine had 1/4-inch-28 screw in it but it had been damaged by PO. Thanks
Pat
Pat
