bluemiata90
I'm in the process of restoring a 61 TR3 with 45000 original miles on it. I'm redoing the body,frame and suspension. I've been debating on if I should have the engine rebuilt(money is becoming a factor). The engine seems of sound and run fine, but I've only driven it about 10 miles since I bought it. I was told it ran great before it was put in storage 2 years ago. I've done a compression test on the cyl. and they came up 180/180/188/180. These figures sound great to me, but I haven't been able to find any information on what the correct readings should be for a engine in good working condition. I'd hate to not rebuild it and put the front nose back on and in a couple of years have to remove it to rebuild the engine later. Do these pressures sound good?. What are the correct pressures?. This information will determine if I rebuild the engine or just replace the oil,water pump, etc. If possible, reply to this site and also to bluemiata90@hotmail.com.
thanks
scott /ubbthreads/images/graemlins/driving.gif
thanks
