martx-5
I'm in the middle of a ground up resto to my TR3, and would like to use a thermostatically controlled electric fan.
What is the procedure...I understand that the original fan assembly provided harmonic balancing for the crank. What can be removed?, and what has to stay?? Also, is there enough room to mount behind the radiator?, or do I need to go with a pusher?
What size and make is generally the best for this application??, And where would I have to mount the thermoswitch to activate the fan??
