Debateable, IMO. The ZS carbs supposedly flow a bit better (for the same throat size), and eliminate the common leakage points on the original SU H6 carbs (jet & float bowl seals). The shorter bodies may also ease problems with clearance to the inner fender when using paper element air filters or the TR4A "bunch of bananas" intake manifold. But there aren't nearly as many different needles available for tuning, and the diaphragms can be troublesome.GBRandy said:I would think the SU carbs would be better. No?
