Re: TR3 Cooling-- 6 blade?
Hi all,
I think the 6-blade metal fan you are thinking about is the same as an optional "Tropical" fan offered with the TR4, intended for use on cars destined for hot climates. It is not listed in the TR4 parts catalogue, however. It is extremely rare.
Regarding Flexi-fans, I've got a 6-blade one I was considering using on my TR4. I did find it would foul on the cross brace between the front shock towers, so carefully trimmed a little off the rear edge of the stainless steel blades. I also had to enlarge the center hole to get it to fit. Still, I'm concerned because it is quite heavy compared to the stock fans. It probably should be balanced, too. There is no doubt this fan would move a lot more air than the original 4-bladed and possibly the Tropical fan, too.
I've also got an early TR6 7-blade plastic fan I might use. Originally it was pale yellow, but the one I have is painted black. I think there was a white version, quite similar, used on the TR250/5. It bolts up easily, directly to the hub, using the original hardware, doesn't require any balancing and is very lightweight. It is considerably smaller diameter and smaller blades than the Flexi-fan, so would surely move less air. But, I think it would out-perform the original 4-blade metal fan.
The item available from TRF and some other vendors is an 8-blade plastic fan, a replica of the one used on later mid-production TR6. It's also quite lightweight, requires no balancing, and bolts right onto the extension hub with the same hardware as the original metal 4-blade fan. The larger diameter and square-end blades will also move quite a bit of air. It is also yellow, a bit brighter color than the earlier 7-blade plastic fan.
There might be some other fans out in the junk yards of the world that would do, too. All in all, it's not difficult to find an improved fan, and there is always the option of using an electric fan.
Cheers!
Alan
