New owner choke questions:
I read in the manual that when the engine is started cold, pull the choke all the way out, switch on the ignition, then press the starter switch button. Then "when the engine has warmed up, turn the choke control and allow it to return to the half-out position and turn to lock in this position. When the engine is sufficiently hot to run without undue hesitation, push the control fully home."
When I pull the choke knob out (goes about an inch), it tries to pull itself back in, to about 1/4 inch from the dash.
I can't feel or see any "half lock" point.
When I cold start the car, am I supposed to *hold* the choke all the way out and keep holding it until releasing and locking to that "half lock" point I don't seem to have? And should there be a natural "half lock" point in the mechanism somewhere?
Thanks.
Tom
Thanks.
Tom
