af3683
When I pull the choke knob all the way out on my TR-3 the front jet lever moves about 1/2 way to the choke cable support on the jet link. When the choke knob is pushed all the way in, the front jet lever is perfectly vertical which is how I believe it should be. I've seen photos on this forum of H6 carbs that when fully choked the jet lever nearly touches the choke cable support. Can anyone tell me if I need to pull more of the choke cable wire through the cable connector which would move the jet lever toward the cable support? I'm not sure that my car is getting fully choked right now, however, I don't want to be driving with the choke partially on all the time either. Thank you very much for your help.
Art
Art
