rlandrum
We got the springs from Moss.
I spent some time last night thinking about this while trying to sleep. It occurs to me that we sort of went about the whole process backward, connecting the cable first then attempting to get the jets sorted, and so on...
I think instead a better solution would have been to get the connecting rod length correct first. Remove the slack from both jet actuators (by holding them in place), then adjust the rod so that any movement of one jet has the identical effect on the other jet. Once that rod length is set, then remove the slack again (by hand), and attach the cable.
I believe the sloppy nature of the linkage is actually what's causing the mechanism to bind slightly, and that removing the slack will have the desired result.
