Does anybody have a picture or a diagram of both carbs with the linkage hooked up? I've been playing with it now for an hour, it sure would speed things up if I had a good picture or schematic.
Also does this look correct? The arm coming off the pedal shaft when the spring is on is pulled forward, and the pedal is high in the car. When it's hooked up to the carbs does that push it back? The spring will have a lot of tension on that way.
