I'm getting everything cleaned up for the assembly of the engine next week and discovered that the cam is one of Kas Kastners. It is in great shape so I was going to use it. I was thinking it was a stock cam in the engine. I've been trying to find what the specs are for the cam without any luck. The only information I can find is that for a F grind cam that he used in a TR4 on the Saltflats. Mine has a D stamped under the his name at the end of the cam. Does anybody have the specs for the D Grind camshaft? The cam also has these numbers on it.
MC21434
301466
It also has the letter G stamped on the shaft near the center bearing.
MC21434
301466
